Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Start by using a spudger or plastic opening tool  to  remove the bottom cover. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible. Once enough of the glue is removed, peel the cover off by hand,
  • Start by using a spudger or plastic opening tool to remove the bottom cover.
  • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  • Once enough of the glue is removed, peel the cover off by hand,
Hier Übersetzung einfügen
