Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device. Under the rubber circle, remove the 1.25 mm screw using a Philips #00 screwdriver. You may need to peel back a piece of double sided tape covering the screw hole.
  • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
  • Under the rubber circle, remove the 1.25 mm screw using a Philips #00 screwdriver.
  • You may need to peel back a piece of double sided tape covering the screw hole.
Hier Übersetzung einfügen
