Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Using a plastic opening tool  or spudger move the keyboard out of position. There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable. If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  • Using a plastic opening tool or spudger move the keyboard out of position.
  • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
  • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
Hier Übersetzung einfügen
