Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand. It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts. It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
  • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
Hier Übersetzung einfügen
