Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
Place the leads of the resistor through the holes on either side of the rectangle marked R1 on the circuit board. Resistors do not have to be installed in a particular orientation. Either lead can go into either hole.
  • Place the leads of the resistor through the holes on either side of the rectangle marked R1 on the circuit board.
  • Resistors do not have to be installed in a particular orientation. Either lead can go into either hole.
  • Turn the board over so that the copper traces are facing up and the resistor leads are pointing straight up in the air, as seen in the second picture.
  • You may also bend the leads outward to hold the resistor in place, but this is not necessary. As per NASA guidelines, any angle up to 30° down from vertical is acceptable.
Hier Übersetzung einfügen
