Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 7
Use the same method above to solder the second resistor lead to the circuit board. After soldering a joint, if you are going to put the soldering iron down, be sure to place it back in its stand to prevent burning yourself or anything around you. Cut the extra lengths of the resistor leads with a pair of wire cutters. NASA workmanship standards state that any length up to 2.29 mm is acceptable.
  • Use the same method above to solder the second resistor lead to the circuit board.
  • After soldering a joint, if you are going to put the soldering iron down, be sure to place it back in its stand to prevent burning yourself or anything around you.
  • Cut the extra lengths of the resistor leads with a pair of wire cutters. NASA workmanship standards state that any length up to 2.29 mm is acceptable.
Hier Übersetzung einfügen
