Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 14
Bend the leads of the small red diode and insert them into the terminal marked D1. Make sure that the cathode (marked by a small black band) lines up with the white stripe to the left of where it says D1 on the circuit board. Use the same method you used to solder the resistors to the board to install the diode.
  • Bend the leads of the small red diode and insert them into the terminal marked D1.
  • Make sure that the cathode (marked by a small black band) lines up with the white stripe to the left of where it says D1 on the circuit board.
  • Use the same method you used to solder the resistors to the board to install the diode.
Hier Übersetzung einfügen
