Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 23
Locate the semi-circle labeled T1 and insert the three leads through the holes. Make sure that you line up the flat part of the transistor with the flat edge of the semi-circle on the board. The two end leads fit into the holes on the ends of the flat part of the drawing. The middle lead will need to be bent so that it feeds through the hole closest to the T1. Solder the three leads to the board and cut the excess off the leads.
  • Locate the semi-circle labeled T1 and insert the three leads through the holes.
  • Make sure that you line up the flat part of the transistor with the flat edge of the semi-circle on the board. The two end leads fit into the holes on the ends of the flat part of the drawing. The middle lead will need to be bent so that it feeds through the hole closest to the T1.
  • Solder the three leads to the board and cut the excess off the leads.
Hier Übersetzung einfügen
