Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
while the lever is up, grip the sides of the panel and pull remove panel, you have to pull up first, then pull toward you pull the plastic guard toward you, and remove using the same method as before
  • while the lever is up, grip the sides of the panel and pull
  • remove panel, you have to pull up first, then pull toward you
  • pull the plastic guard toward you, and remove using the same method as before
  • What you are left with, if your G5 panel says G5 twice, that is ok, it only means that you have two prossessors
Hier Übersetzung einfügen
