Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
Ho!  What's that?  Under a soft spot in the base is a hidden USB connector, presumably used for firmware loading in production. To disassemble the base find 3 screws under the soft spot, punch through using a screwdriver, and remove the screws. After that both parts can be easily separated. To disassemble the base find 3 screws under the soft spot, punch through using a screwdriver, and remove the screws. After that both parts can be easily separated.
Hidden USB Connector
  • Ho! What's that? Under a soft spot in the base is a hidden USB connector, presumably used for firmware loading in production.
  • To disassemble the base find 3 screws under the soft spot, punch through using a screwdriver, and remove the screws. After that both parts can be easily separated.
Hier Übersetzung einfügen
