Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 6
Do not remove the Rear Casing because it is attached via cable to the Main PCB and circuit board. Pry the casing upward slightly, careful NOT to remove it.  Only lift it slightly as shown in the picture.
Step 6
  • Do not remove the Rear Casing because it is attached via cable to the Main PCB and circuit board.
  • Pry the casing upward slightly, careful NOT to remove it. Only lift it slightly as shown in the picture.
  • The LCD is attached to the rear casing via a light coating of adhesive on the underside of the yellow highlighted area. In the next step you will apply light pressure to the LCD to release it from the case.
Hier Übersetzung einfügen
