Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7
Do not apply heavy pressure and Do Not apply uneven pressure.  If you find yourself applying too much pressure then dab some Isopropyl Alcohol 91% using a qtip along the edges to loosen the adhesive. Using your thumbs gently apply pressure to release the LCD.  Both thumbs should be applying even pressure and work your way down to the bottom. Once LCD is free of casing, remove Rear Case.
Step 7
  • Do not apply heavy pressure and Do Not apply uneven pressure. If you find yourself applying too much pressure then dab some Isopropyl Alcohol 91% using a qtip along the edges to loosen the adhesive.
  • Using your thumbs gently apply pressure to release the LCD. Both thumbs should be applying even pressure and work your way down to the bottom.
  • Once LCD is free of casing, remove Rear Case.
Hier Übersetzung einfügen
