Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3
Pull up on the Top Panel Assembly and Remove Use caution while disengaging part.  The part is attached by a socket and the part should remain level with the unit while pulling up Note: Review the picture circled in purple so you can see how the part is attached via socket.  If you bend this socket the camera will no longer function so pull the top panel out straight.
Step 3
  • Pull up on the Top Panel Assembly and Remove
  • Use caution while disengaging part. The part is attached by a socket and the part should remain level with the unit while pulling up
  • Note: Review the picture circled in purple so you can see how the part is attached via socket. If you bend this socket the camera will no longer function so pull the top panel out straight.
Hier Übersetzung einfügen
