Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Now its time to grab a Torckx (star shaped) T6 screwdriver before we continue, because in the next step you will need it. Now its time to remove the front cover, its easy but tricky at the same time, you put the upper side on the table,
Removing front cover and showing the srews
  • Now its time to grab a Torckx (star shaped) T6 screwdriver before we continue, because in the next step you will need it.
  • Now its time to remove the front cover, its easy but tricky at the same time, you put the upper side on the table,
  • The charger/usb/headphone side should be facing you, now you need a little bit of force and your finger nails, pull the front cover away from the main unit until you hear a loud click. It should look as showen on the first picture of this step
  • Now all the screws that are holding the unit toghether should now all be visible
  • There should be 2 above the LCD screen, 2 under the LCD screen, and 2 under the keypad, on the bottomside of the phone.
  • Lets go to the next step
Hier Übersetzung einfügen
