Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
Now take you're screwdriver, and remove those 6 screws you did see in the previous step. Be carefull when you remove the last screw, hold the display assembly in the unit with a finger. Now you can take out the entire display assembly that is attached to the main board.
Removing each screw
  • Now take you're screwdriver, and remove those 6 screws you did see in the previous step.
  • Be carefull when you remove the last screw, hold the display assembly in the unit with a finger.
  • Now you can take out the entire display assembly that is attached to the main board.
  • I take you through the display assembly in the next step, because in the shell that houses the entire display assembly, you see a piece with 2 golden feet on it.
  • That is the microphone, and can be replaced with any microphone of the same type
  • Lets go to the next step
Hier Übersetzung einfügen
