Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
The first ribbon cable to remove is the longer of the two. It overlaps the entire battery. It is marked in orange in the Step 2 image. Using the precision tweezers gently remove the green tape over the clip at the end of the ribbon cable. Last, gently lift the clip lever and the ribbon cable should should easily slide out from its slot.
  • The first ribbon cable to remove is the longer of the two. It overlaps the entire battery. It is marked in orange in the Step 2 image.
  • Using the precision tweezers gently remove the green tape over the clip at the end of the ribbon cable.
  • Last, gently lift the clip lever and the ribbon cable should should easily slide out from its slot.
Entferne zuerst das längere der beiden Flachbandkabel. Es verläuft über den ganzen Akku. Im Bild zu Schritt 2 ist es orange markiert.
Entferne vorsichtig mit einer guten Pinzette das grüne Klebeband von der Klappe am Ende des Flachbandabels.
Hebe die Klappe hoch und schiebe das Flachbandkabel aus dem Anschluss heraus.
