Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 8 übersetzen
Schritt 8
Place the upper casing on its edge and use a spudger to push the keyboard away from the casing, poking the spudger through the central keyboard screw hole. Grasp the keyboard as it separates from the casing. Maintaining your hold on the keyboard, lay the casing flat and gently bow the keyboard until the two tabs on either side of the keyboard come free.
  • Place the upper casing on its edge and use a spudger to push the keyboard away from the casing, poking the spudger through the central keyboard screw hole. Grasp the keyboard as it separates from the casing.
  • Maintaining your hold on the keyboard, lay the casing flat and gently bow the keyboard until the two tabs on either side of the keyboard come free.
  • Slide the keyboard away from the trackpad and out of the upper case.
  • When installing the new keyboard, remember to slip the keyboard backlight ribbon cable through the slot in the top casing.
Hier Übersetzung einfügen
