Schritt 2 übersetzen
Schritt 2
Remove cables attached to bulbs
There is a red latch to release the hold on the connection. Push that down then remove the cable attaching to the right turn signal's bulb. *Note* You can remove just the cable or the bulb depending on your replacement.
The next cable is attached to main bulb in your headlight. Twist the black circle around the cord counter clockwise and you can remove the bulb OR just unclip the latch holding the cable in place. *Note* My replacement came with bulbs so I just took the cable off.
