Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Insert a plastic opening tool under the left side of the keypad backing and start to lift. Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully. Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
  • Insert a plastic opening tool under the left side of the keypad backing and start to lift.
  • Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
Hier Übersetzung einfügen
