Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 15
The daughterboard pops out of the rear case with relative ease, giving us access to the USB Type-C port and the microphone. This is a pretty bare-bones part, which means cheap USB port replacements. Historically, USB ports have been a common failure point (although USB Type-C may prove somewhat more robust in that regard). Unfortunately, USB-C has been having, erm, other issues.
  • The daughterboard pops out of the rear case with relative ease, giving us access to the USB Type-C port and the microphone.
  • This is a pretty bare-bones part, which means cheap USB port replacements. Historically, USB ports have been a common failure point (although USB Type-C may prove somewhat more robust in that regard).
  • Unfortunately, USB-C has been having, erm, other issues.
  • We found a few bits of silicon on the daughterboard:
  • Qualcomm QFE2550 dynamic antenna matching tuner.
  • AKM Semiconductor AK8789 Hall-effect sensor
  • NXP Semiconductor PTN36241G USB 3.0 redriver
  • ON Semiconductor FUSB340 USB 3.1 SuperSpeed 10 Gbps switch
Die Tochterplatine kommt ziemlich leicht aus dem Gehäuse heraus, so dass wir an den USB-C Anschluss und das Mikrofon herankommen.
Das ist ein ziemlich simples Einzelteil, was bedeutet, dass der USB-Anschluss leicht ausgetauscht werden kann. Bisher waren diese Anschlüsse eine häufige Fehlerquelle (obwohl USB-C sich vielleicht in dieser Hinsicht als robuster erweisen könnten.)
Unglücklicherweise hat USB-C ,ääähm, andere Probleme.
Auf der Tochterplatine haben wir ein Stück Silizium gefunden: einen Qualcomm QFE2550 Tuner mit dynamischen Antennenabgleich.
[* black] The daughterboard pops out of the rear case with relative ease, giving us access to the USB Type-C port and the microphone.
[* black] This is a pretty bare-bones part, which means cheap USB port replacements. Historically, USB ports have been a common failure point (although USB Type-C may prove somewhat more robust in that regard).
[* icon_reminder] Unfortunately, USB-C has been having, erm, [http://www.theverge.com/2016/2/4/10916264/usb-c-russian-roulette-power-cords|other issues|new_window=true].
-[* red] We found one bit of silicon on the daughterboard: a Qualcomm [https://www.qualcomm.com/videos/qualcomm-rf360-dynamic-antenna-matching-tuner-qfe2550|QFE2550|new_window=true] dynamic antenna matching tuner.
+[* black] We found a few bits of silicon on the daughterboard:
+ [* red] Qualcomm [https://www.qualcomm.com/videos/qualcomm-rf360-dynamic-antenna-matching-tuner-qfe2550|QFE2550|new_window=true] dynamic antenna matching tuner.
+ [* orange] AKM Semiconductor [https://www.akm.com/global/en/products/magnetic-sensor/hall-effect-ic/hall-effect-ic-switch/ak8789/|AK8789] Hall-effect sensor
+ [* yellow] NXP Semiconductor [https://www.nxp.com/products/interfaces/signal-conditioners/superspeed-usb-3-0-redriver:PTN36241G|PTN36241G] USB 3.0 redriver
+ [* green] ON Semiconductor [https://www.onsemi.com/products/interfaces/analog-switches/fusb340|FUSB340] USB 3.1 SuperSpeed 10 Gbps switch
