Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 15 übersetzen
Schritt 15
Samsung Galaxy Nexus Repairability Score: 6 out of 10 (10 is easiest to repair). Battery replacement is incredibly simple thanks to the removable rear panel.
  • Samsung Galaxy Nexus Repairability Score: 6 out of 10 (10 is easiest to repair).
  • Battery replacement is incredibly simple thanks to the removable rear panel.
  • Minimal adhesive makes removal of the motherboard and other components a snap.
  • Headphone jack and speaker assembly are not soldered to the motherboard, so replacement is easy.
  • The only soldered components are the volume switch and vibrator motor.
  • Removing the rear case to access the motherboard and other internals requires a lot of careful prying and guitar-picking.
  • The glass is fused to both the display and the display frame. So don't crack the glass unless you're good with a heat gun, or you're fond of replacing the glass, display, and frame together ($$$).
Hier Übersetzung einfügen
