Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 25 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad. Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
  • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
Während du das Display mit dem Saugnapf anhebst, führe ein Opening Pick in die Lücke zwischen dem Glas und dem iPad Gehäuse ein.
Füge das Opening Pick nur soweit ein, wie der Schwarze Rand am Display breit ist (ca. 2mm). Falls du das Pick zu weit einführst, kannst du das Display, die Hintergrundbeleuchtung oder den Touchscreen beschädigen.
[* black] While holding the glass up with the suction cup, slideinsert the point of an opening pick into the gap between the glass and body of the iPad.
[* icon_caution] Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
