Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver. Carefully peel back the trunk liner from around the edge of trunk opening by the light. Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
Panel Tail Lights
  • Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
  • Carefully peel back the trunk liner from around the edge of trunk opening by the light.
  • Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
Hier Übersetzung einfügen
