Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 11
Remove the following T3 screws securing the midframe:
  • Remove the following T3 screws securing the midframe:
  • Thirteen 3.1 mm black screws
  • Four 4.3 mm silver screws
  • Due to screw and bit variance, you may have better luck with a T4 driver. The proper bit should seat fully in the screwhead and feel slightly loose. The bit should not feel like it's stuck in the screwhead.
Entferne folgende Torx T3 Schrauben, welche den Mittelrahmen befestigen:
Dreizehn schwarze 3,1 mm Schrauben
Vier silbernfarbene 4,3 mm Schrauben
Bit-Einsätze passen nicht immer 100-prozentig. Wenn ein T4 nicht ganz passt, probiere es mit einem T3.
[* black] Remove the following T3 screws securing the midframe:
[* red] Thirteen 3.1 mm black screws
[* orange] Four 4.3 mm silver screws
+ [* icon_note] Due to screw and bit variance, you may have better luck with a T4 driver. The proper bit should seat fully in the screwhead and feel ''slightly'' loose. The bit should not feel like it's stuck in the screwhead.
