Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 3
According to Apple, this MacBook Pro's dimensions match exactly with those of the "Escape Edition" machine we tore down a couple weeks ago. Do we believe it even for a second? Yes we do. Do you miss your function keys? Hold down the Function key to see your missing function keys. Chameleon Mode, engage. One thing that is noticeably different is, of course, the port situation on the starboard side. This Touch Bar-equipped machine packs two extra Thunderbolt ports, so you have twice as many places to plug in your dongles.
  • According to Apple, this MacBook Pro's dimensions match exactly with those of the "Escape Edition" machine we tore down a couple weeks ago. Do we believe it even for a second? Yes we do.
  • Do you miss your function keys? Hold down the Function key to see your missing function keys. Chameleon Mode, engage.
  • One thing that is noticeably different is, of course, the port situation on the starboard side. This Touch Bar-equipped machine packs two extra Thunderbolt ports, so you have twice as many places to plug in your dongles.
  • Throwing both machines onto the scale, we find the Touch Bar version weighs about 20 grams less than its counterpart. We're chalking the difference up to this laptop's smaller battery.
  • Finally, we note a pair of side vents on the underside of the Touch Bar version, similar to the ones we've spotted in previous Retina MacBook Pros—but absent from the Function Key model.
Apple zufolge sind die Maße dieses MacBook Pro genau die gleichen wie die des "Escape" Modells, das wir vor ein paar Wochen auseinandergenommen haben. Glauben wir da etwa auch nur eine Sekunde dran? Ja, das tun wir.
Vermisst du deine Funktionstasten? Dann halte die Taste "Funktion" gedrückt und deine vermissten Funktionstasten tauchen wieder auf. Chamäleon-Modus aktiviert.
Es gibt etwas, das sich deutlich unterscheidet, und zwar natürlich die Port-Situation auf der Steuerbordseite. Dieses mit Touch Bar ausgestattete Gerät verfügt über zwei zusätzliche Thunderbolt Ports, sodass du doppelt soviel Platz hast, um deine Dongles einzustecken.
Wir legen beide Geräte auf die Waage und stellen fest, dass die Touch Bar Version 20 Gramm leichter ist als sein Gegenstück. Wir schieben diesen Unterschied auf den kleineren Akku dieses Laptops.
Und zum Schluss vermerken wir noch zwei seitliche Lüftungsöffnungen auf der Unterseite der Touch Bar Version, ähnlich denen, die wir bei früheren Retina MacBook Pros gefunden haben, die jedoch beim Funktionstasten-Modell fehlen.
