Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 16
The sync button is a self-contained li'l clicky dude, with contacts that match up to some spring contacts on the main board. Electrical switches can be complicated. This one, however, probably isn't. It is likely a pushbutton switch. A press of the button closes the circuit and lets current flow. This current will flow into the circuit and be interpreted as input. We told you it was simple. Electrical switches can be complicated. This one, however, probably isn't. It is likely a pushbutton switch. A press of the button closes the circuit and lets current flow. This current will flow into the circuit and be interpreted as input. We told you it was simple.
  • The sync button is a self-contained li'l clicky dude, with contacts that match up to some spring contacts on the main board.
  • Electrical switches can be complicated. This one, however, probably isn't. It is likely a pushbutton switch. A press of the button closes the circuit and lets current flow. This current will flow into the circuit and be interpreted as input. We told you it was simple.
Hier Übersetzung einfügen
