Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 17
We loosen a pair of Phillips screws to access the Lightning connector, pop its press connector off the back of the logic board, and seconds later it's free to leave this plastic mess behind. Luckily, the Lightning port is modular—so if you wear your port out, all you have to do is utterly destroy the case to replace that component. The logic board is secured with a lot of sticky tape.
  • We loosen a pair of Phillips screws to access the Lightning connector, pop its press connector off the back of the logic board, and seconds later it's free to leave this plastic mess behind.
  • Luckily, the Lightning port is modular—so if you wear your port out, all you have to do is utterly destroy the case to replace that component.
  • The logic board is secured with a lot of sticky tape.
Hier Übersetzung einfügen
