Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
With the midframe removed, it is also possible to replace the M.2 SSD during this step The hard drive is underneath the heatsink so the heatsink must be removed Remove four spring loaded torx screw labeled 1 to 4
  • With the midframe removed, it is also possible to replace the M.2 SSD during this step
  • The hard drive is underneath the heatsink so the heatsink must be removed
  • Remove four spring loaded torx screw labeled 1 to 4
  • Remove three torx screw labeled 5 to 7
  • Remove 5mm hex mounting post
  • Use a spudger to remove the heatsink assembly from the motherboard
Hier Übersetzung einfügen
