Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Optical Drive
  • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  • On some models, the subwoofer connector is soldered to the logic board and will break if you pry it off. If you need to replace the speaker/subwoofer, you can pull back the foam padding on the connector and remove the red and black wires to disconnect. You will need to reinsert the wires from the new speaker to reconnect.
  • If you are only removing the optical drive and not replacing the speaker/subwoofer, you do not need to disconnect this connector.
Verwende das Flache Ende eines Spudgers, um den Subwooferanschluss gerade nach oben vom Logic Board zu entfernen.
[title] Optical Drive
[* black] Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
[* icon_caution] On some models, the subwoofer connector is soldered to the logic board and will break if you pry it off. If you need to replace the speaker/subwoofer, you can pull back the foam padding on the connector and remove the red and black wires to disconnect. You will need to reinsert the wires from the new speaker to reconnect.
[* icon_note] If you are only removing the optical drive and not replacing the speaker/subwoofer, you do not need to disconnect this connector.
