Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 4
The adjustment procedure for the front brake is the same as for the rear brake.  Loosen the two screw nuts, position the brake so that the brake disc doesn't roam to one side of the brake caliper, tighten screw nuts afterwards with 9-10 Nm. The adjustment procedure for the front brake is the same as for the rear brake.  Loosen the two screw nuts, position the brake so that the brake disc doesn't roam to one side of the brake caliper, tighten screw nuts afterwards with 9-10 Nm. The adjustment procedure for the front brake is the same as for the rear brake.  Loosen the two screw nuts, position the brake so that the brake disc doesn't roam to one side of the brake caliper, tighten screw nuts afterwards with 9-10 Nm.
Front brake
  • The adjustment procedure for the front brake is the same as for the rear brake. Loosen the two screw nuts, position the brake so that the brake disc doesn't roam to one side of the brake caliper, tighten screw nuts afterwards with 9-10 Nm.
Der Vorgang für die Feineinstellung des Vorderrads ist der selbe wie bei deinem Hinterrad. Lockere die beiden Schrauben, bringe die Bremsscheibe in eine gerade Position ohne dass sie an einer Seite des Bremssattels streift und ziehe die Schrauben danach wieder mit 9 bis 10 Nm fest.
