Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3
I find it easiest to prop up the top shell on the front right corner of the system. If you're using a flat surface it can stand by itself and there's enough slack in the Genesis PCB and Dial Switch cables to allow it to be positioned in such a way.
Remove screws securing the PCBs to lower shell
  • I find it easiest to prop up the top shell on the front right corner of the system. If you're using a flat surface it can stand by itself and there's enough slack in the Genesis PCB and Dial Switch cables to allow it to be positioned in such a way.
  • You can barely see it but the upper shell is standing upright on the front right corner.
  • There are 11 screws that need to be removed in order to remove the entire PCB unit.
  • If the IR lens cover pops out at this point don't worry about it. It can be easily reinstalled during the reassembly process.
Hier Übersetzung einfügen
