Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it. Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left. Set the plastic base beside the laptop by opening it as if you were opening a book.
  • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
  • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
  • Set the plastic base beside the laptop by opening it as if you were opening a book.
Hier Übersetzung einfügen
