Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2
Gently pry off the six rubber covers around the outside of the screen using a two mm flat head screwdriver. A flat head screwdriver is preferable over a spudger as the spudger's head is not thin enough to to slip under the rubber covers. Remove the six 4.76 mm Phillips #0 screws underneath each cover.
  • Gently pry off the six rubber covers around the outside of the screen using a two mm flat head screwdriver.
  • A flat head screwdriver is preferable over a spudger as the spudger's head is not thin enough to to slip under the rubber covers.
  • Remove the six 4.76 mm Phillips #0 screws underneath each cover.
Hier Übersetzung einfügen
