Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 5
Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated. The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool. The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
  • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
Hier Übersetzung einfügen
