Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Unscrew the two 3mm screws from both sides of the barrel clip  with a 3.0 flathead screwdriver to remove the clip from the barrel. Set the two screws and barrel clip aside for reassembly at a later point.
  • Unscrew the two 3mm screws from both sides of the barrel clip with a 3.0 flathead screwdriver to remove the clip from the barrel.
  • Set the two screws and barrel clip aside for reassembly at a later point.
  • Clip is prone to pop off from the body due to the weight of the spring. Equally loosen each screw little by little to prevent this.
Hier Übersetzung einfügen
