Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Use a T8 Torx Security screwdriver to remove five screws from the rear of the device. Two 31mm screws. Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
  • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
  • Two 31mm screws.
  • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
  • Remove the metal plate by pulling it up.
Entferne fünf Torx T8 Security Schrauben auf der Rückseite des Geräts.
Zwei 31 mm Schrauben.
Drei 10 mm Schrauben.
Ziehe die Metallplatte nach oben und entferne sie.
[* black] Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
[* red] Two 31mm screws.
[* orange] Three 10mm screwsscrews for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
[* black] Remove the metal plate by pulling it up.
