Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 8
Use a suction cup to firmly pull the screen away from the frame. The Nexus 5 has a very thin layer of adhesive. This should not require excessive force. Apply additional heat as needed to soften the screen adhesive.
  • Use a suction cup to firmly pull the screen away from the frame.
  • The Nexus 5 has a very thin layer of adhesive. This should not require excessive force. Apply additional heat as needed to soften the screen adhesive.
Verwende einen Heavy Duty Saugheber, um den Bildschirm entweder komplett vom Rahmen abzulösen, oder um einen Spalt zwischen Bildschirm und Rahmen zu erzeugen.
Das Nexus 5 hat eine sehr dünne Klebeschicht. Dieser Schritt sollte nicht viel Kraft benötigen. Erwärme den Klebstoff, wenn notwendig, erneut, um ihn aufzuweichen.
-[* black] Use a [product|IF145-023-2|heavy duty suction cup] and firmly pull the screen away from the frame entirely, or enough to create a small gap.
+[* black] Use a suction cup to firmly pull the screen away from the frame.
[* icon_note] The Nexus 5 has a very thin layer of adhesive. This should not require excessive force. Apply additional heat as needed to soften the screen adhesive.
