Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Use the flat end of a nylon spudger to pry the white and black antenna connectors up off the daughterboard. These must be firmly secured during reassembly. Failure to secure the antenna connections will affect your reception and call quality. These must be firmly secured during reassembly. Failure to secure the antenna connections will affect your reception and call quality.
  • Use the flat end of a nylon spudger to pry the white and black antenna connectors up off the daughterboard.
  • These must be firmly secured during reassembly. Failure to secure the antenna connections will affect your reception and call quality.
Verwende das flache Ende eines Spudgers, um den weiße und den schwarze Antennenstecker vom Daughterboard zu trennen.
Die beiden Kabel müssen beim Wiederzusammenbau gut befestigt werden. Bei fehlerhaftem Zusammenbau, werden Empfang und Gesprächsqualität stark beeinträchtigt.
