Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5
Use an iOpener or heat gun and carefully apply heat to the digitizer panel to soften the adhesive that secures it to the frame.
  • Use an iOpener or heat gun and carefully apply heat to the digitizer panel to soften the adhesive that secures it to the frame.
  • Hold the heat gun approximately 8-10 inches from the device and apply heat in a gentle back-and-forth motion.
Verwende ein Heißluftgebläse, um vorsichtig den Kleber, der das Touch Panel am Rahmen befestigt, zu lösen.
Halte das Heißluftgebläse ca. 20-25cm vom Gerät entfernt und bewege es beim Erwärmen leicht hin und her.
-[* red] Use a heat gun and carefully apply heat to the digitizer panel to soften the adhesive that secures it to the frame.
+[* red] Use an iOpener or heat gun and carefully apply heat to the digitizer panel to soften the adhesive that secures it to the frame.
[* icon_note] Hold the heat gun approximately 8-10 inches from the device and apply heat in a gentle back-and-forth motion.
