Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Insert the flat side of a nylon spudger below the digitizer ribbon cable to free it from the adhesive. You may use your fingers to pull the ribbon cable gently as you free the panel from the adhesive with the spudger. It may be necessary to apply more heat if the adhesive is still too strong.
  • Insert the flat side of a nylon spudger below the digitizer ribbon cable to free it from the adhesive.
  • You may use your fingers to pull the ribbon cable gently as you free the panel from the adhesive with the spudger. It may be necessary to apply more heat if the adhesive is still too strong.
Hier Übersetzung einfügen
