Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob. Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob. Remove the bottom portion of the key fob.
  • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
  • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
  • Remove the bottom portion of the key fob.
Setze einen Schlitzschraubendreher (oder einen Spudger, Jimmy oder Opening Tool) in den Schlitze zwischen den Schlüsselhälften ein.
Hebele mit Schraubendreher die beiden Schlüsselhälften auseinander.
Entferne die untere Schlüsselhälfte.
