Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red). Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it. Repeat this step with the other adhesive strip and remove it.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
  • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
  • Repeat this step with the other adhesive strip and remove it.
  • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
Du kannst, wenn nötig, verbliebene Reste des unteren Klebestreifens mit einer Plastikkarte ablösen.
-[* icon_note] If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
+[* icon_caution] Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
+[* black] Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
+[* black] Repeat this step with the other adhesive strip and remove it.
+[* icon_note] If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
