Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
Apply pressure out the outter tip near pin pushing in slightly and gently release the pin from the barrel.  Do this on all three locations where the pins are located. I have seen people push the focus ring outward to release the pins... which works but you need to be careful because the focus ring is fragile and it can bend easy.  If you bend the focus ring then you will have a lens that jams.
Remove focus ring Step #2
  • Apply pressure out the outter tip near pin pushing in slightly and gently release the pin from the barrel. Do this on all three locations where the pins are located.
  • I have seen people push the focus ring outward to release the pins... which works but you need to be careful because the focus ring is fragile and it can bend easy. If you bend the focus ring then you will have a lens that jams.
Üben Druck auf die Außenspitze in der Nähe des Stifts aus, indem du leicht hineindrückst und den Stift vorsichtig aus dem Lauf löst. Tue dies an allen drei Stellen, an denen sich die Stifte befinden.
Ich habe Leute gesehen, die den Fokusring nach außen gedrückt haben, um die Stifte freizugeben ... das funktioniert, aber du musst vorsichtig sein, da der Fokusring zerbrechlich ist und sich leicht verbiegen kann. Wenn du den Fokusring verbiegst, klemmt das Objektiv.
