Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Remove both metal brackets from the original LCD screen. Remove 2 torx screws from each side. Each bracket should then be easily removed. Remove the LCD inverter from the metal bracket. It is held in with some light adhesive.
  • Remove both metal brackets from the original LCD screen.
  • Remove 2 torx screws from each side. Each bracket should then be easily removed.
  • Remove the LCD inverter from the metal bracket. It is held in with some light adhesive.
  • You can use a spudger to lift the inverter board slightly. Then it will come out easily.
Hier Übersetzung einfügen
