Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
Remove the single Phillips screw securing the inverter to the logic board. Lift the inverter straight up off the pins on the logic board.
  • Remove the single Phillips screw securing the inverter to the logic board.
  • Lift the inverter straight up off the pins on the logic board.
  • Be sure to lift the inverter straight up off the logic board, as the connector pins are very long and easily bent. If the pins bend during removal, use the connector on the inverter as a guide to bend them straight.
Hier Übersetzung einfügen
