Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
There is one last cable which connects the display to the computing unit. On both ends it has a simple plug-in connection. Under a strip of protective film we can find the control board, with:
  • There is one last cable which connects the display to the computing unit. On both ends it has a simple plug-in connection.
  • Under a strip of protective film we can find the control board, with:
  • a HIMAX HX8876 timing controller
  • a NovaTek NT50169G power management (likely)
  • a Richtek RT8532GQW backlight white LED driver w/ boost converter
Ein letztes Kabel, welches an beiden Ende eine einfache Steckverbindung hat, verbindet den Bildschirm noch mit der Recheneinheit.
Unter einem Schutzstreifen finden wir die Kontrolleinheit des Bildschirms, mit einem HIMAX HX8876 Timing Kontrollchip vor.
[* black] There is one last cable which connects the display to the computing unit. On both ends it has a simple plug-in connection.
-[* red] Under a strip of protective film we can find the control board with a HIMAX HX8876 timing controller chip.
+[* black] Under a strip of protective film we can find the control board, with:
+ [* red] a HIMAX HX8876 timing controller
+ [* orange] a NovaTek NT50169G power management (likely)
+ [* yellow] a Richtek [link|https://www.richtek.com/Products/LED%20Driver/backlight-led/RT8532?sc_lang=en&specid=RT8532|RT8532GQW] backlight white LED driver w/ boost converter
