Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
A soldering iron that can reach at minimum 650F is required.  If you are having trouble desoldering the old analog sticks, add fresh solder to make removal of the old analog sticks easier.
Desolder Ground Pins
  • A soldering iron that can reach at minimum 650F is required. If you are having trouble desoldering the old analog sticks, add fresh solder to make removal of the old analog sticks easier.
  • Desolder the left analog stick from the controller.
  • Desolder the right analog stick from the controller.
Stelle deinen Lötkolben auf 350° C ein. Wenn die Lötstellen nicht schön schmelzen, hilft ein wenig frisches Lötzinn.
Löte den linken Joystick vom Controller ab.
Löte den rechten Joystick vom Controller ab.
[title] Desolder Ground Pins
-[* icon_note] A 650 watt soldering iron is required. If you are having trouble desoldering the old analog sticks, add fresh solder to make removal of the old analog sticks easier.
+[* icon_note] A soldering iron that can reach at minimum 650F is required. If you are having trouble desoldering the old analog sticks, add fresh solder to make removal of the old analog sticks easier.
[* red] Desolder the left analog stick from the controller.
[* orange] Desolder the right analog stick from the controller.
