Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
These can be difficult to desolder. It is best to use a 650F degree soldering iron, if you have this available. If you are having trouble desoldering it with the old solder, adding fresh solder makes removal of the old solder easier.
Desolder Button Pins
  • These can be difficult to desolder. It is best to use a 650F degree soldering iron, if you have this available. If you are having trouble desoldering it with the old solder, adding fresh solder makes removal of the old solder easier.
  • Desolder the 4 pins holding the pins in on the left analog stick.
  • Desolder the 4 pins holding the button in on the right analog stick.
Stelle deinen Lötkolben auf 350° C ein. Wenn die Lötstellen nicht schön schmelzen, hilft ein wenig frisches Lötzinn.
Entlöte die vier Lötstellen am linken Joystick.
Entlöte die vier Lötstellen am rechten Joystick.
