Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove four rubber grommets, They are glued well, so it requires some force. The screw head is non-standard (Torx T9 or T10) with a "security pin". If you lack the Torx bit, you can use a thin flathead screwdriver (appx. 1.5mm) to jam into the slot. :)
Remove 4 screws
  • Remove four rubber grommets, They are glued well, so it requires some force.
  • The screw head is non-standard (Torx T9 or T10) with a "security pin".
  • If you lack the Torx bit, you can use a thin flathead screwdriver (appx. 1.5mm) to jam into the slot. :)
  • On my router, I could easily snap off that screw head pin, allowing me to use standard bits.
Hier Übersetzung einfügen
