Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 4
Serial interface (4 "pins") are unsoldered, and can be found in the top-right corner of the board (if the Ethernet ports were facing you). A close-up image crop shows the 4 serial through-hole "pins". Pinout: pin1 : VCC +3.3V
Internals top (pt.1)
  • Serial interface (4 "pins") are unsoldered, and can be found in the top-right corner of the board (if the Ethernet ports were facing you).
  • A close-up image crop shows the 4 serial through-hole "pins". Pinout:
  • pin1 : VCC +3.3V
  • pin2 : GND
  • pin3 : TX
  • pin4 : RX
  • If you wish to connect using a USB TTL adapter, I suggest soldering female "jumper" wires and routing those outside the case. DO NOT CONNECT TO VCC (do not apply external power!)
  • The serial port is enabled by default, and you can watch Linux boot. If you Google around, you can find how to login to the console (this varies by OS installed on the router).
Hier Übersetzung einfügen
